Early A/ TTI/ X-Pipe Question.............
65BCODA
EUSTIS,FL
65 Barracuda w/TTI's looking to put an x-pipe on, not really wanting to spend the $265 + freight for their adjust to fit X.
The TTI flange adapter on the passenger side "kicks" over toward center to take advantage of the modified tranny crossmember.
Has any one used a Pypes,Summit or otherwise with success?
My concern from looking at catalogs are that they look way wide and would have to be modded a good deal. Not that I'm not capable but time at home is at a premium.
Any input is appreciated,
Roger
You could get the X-pipe from whoever and then get a muffler shop to bend the X-connectors for you.
Or you could order a few U-bends and weld your own X-pipe connectors. I even think Summit sells the U-bends.
Either way you'll be spending time and cash. You just have to decide which is more of a premium.
