early exhaust manifolds fit 67-69 cars?
VDART
Shulte Ks
I have a 69 dart-- that has a 318-- Will the early style pre-67 exhaust manifolds fit? what is the difference between the early "a" manifolds & the 67-69 style -- if any? thanks-- I know the 340 style is a better unit & more $$ but this car is going to be a croozer-- doesn't need speed.
the car rolls right now so it will be a while before i get to this point. thanks Lawrence
yeah they will fit. The pass side is the same casting. The pre 67 drivers side manifold had a different little crook in the dump end so it doesn't flow quite as well but both will fit in 2nd generation As.
But why would you want to? They don't exactly flow well. In fact typical 67-76 318 manifolds are probably better.
