Krooser
Building Chinese Free Engines since 1959...
Okay... I have a brand new Hot Heads 360-style M72HV oil pump that has been modified to fit a 331/354 rear main cap. No oilpump pickup. These sell for around $150.00 as is. Never mounted. I used a stock 354 pump in my build so this is just excess to my needs. I'd like $100.00 shipped to the lower 48. PM for details. I like Paypal. This is also advertised on the HH swap forum and Fleabay. Early bird gets the worm. PUMP IS SOLD!
I also have some 354 head bolts. Nice, clean parts. I believe I have the complete set. I will check. $25.00 shipped to the lower 48.
I also have a 331/354 spark plug wire cover. Has surface rust and a slight bend in it. EZ fix. $20.00 shipped.
I have a NOS stick shift flywheel for a 10.5" clutch that will fit under a modern small block bellhousing. 8 bolt for an early Hemi. You will need an adaptor to mate the block to the bellhousing. This was modified from a six bolt deal at a local machine shop. Plugged and redrilled. Nice quality work. $50.00 plus the ride.
