bremereric
Enlarge product image
Eastwood Thermo-Coustic Sound Deadener Material
Item #12117
Only $149.99
Banish road noise, floor pan vibration and exhaust heat from your ride! Our Thermo-Coustic Barrier conforms easily to interior and door panels (a hi-tack adhesive lets you install them securely -- even up underneath a trunk lid). The sound deadening sheets are designed with a .06 thick layer of butyl rubber material, bonded to a high-performance aluminum facing, for an overall thickness of 0.063". Along with a significant reduction in road noise and driveline vibration, the sheets help keep heat from penetrating your vehicles interior. In testing, we found that performance is equivalent to that of the expensive major brand. Kit includes 36 sq. ft -- enough material to insulate the most critical portions of your cars interior and door panels. For more complete coverage, order two kits (particularly if you have removed the factory sound deadening during restoration). Compare to Dynamat liners.
