U usdart Well-Known Member Joined Dec 28, 2005 Messages 248 Reaction score 1 Location West Richland, Wa Nov 7, 2007 #1 Will a 14" Ford Aerostar rim fit my 79 Volare? I have a chance for some studded snow tires for a good price
3 340mopar Sorgermotorsports Joined Jan 25, 2006 Messages 3,604 Reaction score 12 Location Soap Lake, WA Nov 7, 2007 #2 The bolt pattern is the same but I believe the center (hub) hole is a little smaller on the ford. Chuck
GTXperience Orig Stealth Mod Joined Jul 13, 2007 Messages 6,541 Reaction score 275 Location Sacramento Area, CA Nov 7, 2007 #3 Not so easy if you don't know the bolt patterns of both. If they are the same then all you need to check is the ID (inside diameter) to see if it will fit the hub. Sometimes, Ford applications are just a 1/16" off (which can be opened to fit).
