halifaxhops submitted a new Article:
easy tool for removing roof rail mouldings
Read more about this article here...
Easy tool to make from a churchkey, heat shrink and a popsical stick. Bend the can opener and grind the tip off of the can side. Open the tab on the bottle side a bit. Then put a bit of heat shrink or tape over the tab. I use hot glue to put the section of the popsicle stick on. (you will...
