Eddy heads and HP manifolds
70Duster340
Cortland, Ohio
Has anyone here had any experience with Eddy heads and the HP manifolds on a 340? I have been told that there is clearance problems with installing the HP manifolds on these heads. I have a set of the heads ready to install, and a set of the HP manifolds with the TTI system attached. Not a whole lot of room for movement due to the torsion bars as close to the pipes as they are.
Can anyone help here? :scratch:
Thanks,
Chuck
The Eddy heads will have clearance problems with any of the stock manifolds. You will have to get headers.
OR....(EEEEEK) machine the heads or manifolds to fit.
