Edelbrock 340 Super Victor intake..
stroked340
mass.
Anyone using one how ya' like it thinking of buying one..
Thinking of one for up top that stroker coming?
Your doing a 4.25 crank?
Which one are we talking about?
There is an Edelbrock Victor 340/360 and an Edelbrock Super Victor S/B Chrysler. Big differences between the two.
We used the Super Victor S/B Chrysler on a 426/360 and it made 596 HP on 91 octane.
450 lb-ft from 3000-6700 rpm, 500 lb-ft from 4000-6100 rpm, 550 lb-ft from 4700-5100 rpm and 557 lb-ft peak @ 5000 rpm.
I think we have the bugs worked out and it should run better the next time on the dyno.
Hey Jim, whatcha do for a cam on that mill?
Comp ratio?
Talking super victor...
Yes,Rumble going with 4.25 stroke..
Comp ratio?
It was a .630" lift custom solid roller we designed for the flow out of the Racemaster/ProComp cylinder heads we ported. Right at 10.9:1 compression.
Need a lot of work out of the box. Ports are cast small, and sits high on the heads ie needs milled down for good fitment. On my 10 to 1 comp .712 lift 249 @ .050 365 cu CNC ported IndyBrock 590 HP motor the SV was worth 45 HP over a port matched RPM AirGap.
I have a super victor on my 416. Motor is strong runs 10.56 I recommend it. I'm using a 950 quick fuel carb on top. With indy t/a heads with full port job.
