Hi, I have a real nice LD 340 intake & carb, the intake has been gasket matched, painted 1st. with high temp. as cast aluminum paint, then high temp. clear coat, has new manifold to carb gasket, and new carb studs, nuts, & washers, crome water inlet, and vacume tee, carb only has 700 mi. on it, and is like new, # 4777-c, with mech. sec.,manual choke, crome dual feed fuel line, and carb to air cleaner gasket, I'm in valley springs, Ca., 95252, $320.00 shipped anywhere in the lower 48, I will only take a postal money order. Thanks Jeff
