[FOR SALE] Edelbrock Magnum Cylinder Heads
Dodge74
sunny FL
Rating - 66.7%
2   1   0
For sale, set of Edelbrock Magnum cylinder heads with less than a 100 miles on them. They are in perfect condition. Heads will come with Hughes Engines billet aluminum rocker arms. Also included, set of ARP headbolts, and Hughes thick-wall push rods. $1900 buyer pays for shipping.
It's for the roller cam but I hear you can also use this head for the flat tap lifter..
Are they drilled for the LA manifold setup or Mag manifold only ?
Thanks
Can I get an idea of weight and approx. dimensions so I can scout some shipping costs?
I have no idea of how much they weigh maybe if you can look on summitracing.com maybe they give dimensions and weight. But with my experience shipping each cylinder heads going to be about 48 to $50 a piece plus rocker arms. Maybe I can find a box that will fit rocker arms and cylinder heads all in one. And that's probably a real accurate guesstimate
