Edelbrock Performer-plus cam and lifters
pishta
I know I'm right....
Tustin, CA
LA 273-360 hydraulic. not roller
Camshaft #2177 270/.420 lift, great low and mid idle-5500 camshaft with matching lifters in order. Slight choppy idle, but no driveablilty issues.
$70 plus shipping from So. Cal [email protected]
From web:
Edelbrock Performer-Plus Camshaft Kit are designed for optimum torque from the low-end to the mid-range. Performer-Plus camshafts match Performer manifolds for vehicles operating from off-idle to 5500 RPM. They are smooth-idling cams for daily drivers, trucks, vans, RVs, and 4x4s. You can expect major improvement in throttle response and torque.
Duration Advertised 270° Intake/270° Exhaust
Duration @ .050'' 204° Intake/204° Exhaust
Lift @ Valve .420'' Intake/.420'' Exhaust
Lift @ Cam .280'' Intake/.280'' Exhaust
Lobe Separation Angle 110°
Intake Centerline 106°
Intake Timing @ .050" Open 4° ATDC
Close 28° ABDC
Exhaust Timing @ .050" Open 36° BBDC
Close 12° BTDC
Met pishta and bought the cam and lifters. Saw his '65 Barracuda project. He's a good guy.
Thanks Steve.
Thanks FABO.
