Edelbrock pro flow 2 fuel injection, anybody ever use it?
hemichuck
Louisville Kentucky
I have a chance to pick up an Edelbrock pro flow 2 fuel injection system for a small block and I was wondering if anyone was familiar with these units and knows their limitations.
I dont have any advice on this particular system. But I have learned. Do not buy any fuel system items until your build is almost at the completion phase. The reason is: updates and new releases. If you buy early in the build chances are it will be outdated by the time she ready to run.
Also, I would not buy a system that does not run a wide band 02 anymore. My Holley 950 didn't start out with a wide band. I had to upgrade. I've also had to send stuff in for firmware up grades and the car hasn't moved yet. Just finished the paint.
To my knowledge there is not a current system out there that uses anything else. Megasquirt, you have to add your own wideband on top of the rest of the cost.
