340Dart Obsessive Dart Disorder FABO Gold Member Joined Jan 8, 2005 Messages 778 Reaction score 233 Location Mount Morris, New York Mar 18, 2006 #1 I just bought a set for my 340. Do you use the same plugs as the cast iron heads or not?
halfaed Well-Known Member Joined Nov 8, 2004 Messages 386 Reaction score 3 Location Trempealeau, WI Mar 18, 2006 #2 They are supposed to be factory replacement, But I don't know if you do. Someone will be along pretty soon to let you know!
dustertogo Well-Known Member Joined Mar 7, 2006 Messages 880 Reaction score 209 Location Brandon, MS Mar 18, 2006 #3 Are you asking about the size of the plugs, or heat range?
340Dart Obsessive Dart Disorder FABO Gold Member Joined Jan 8, 2005 Messages 778 Reaction score 233 Location Mount Morris, New York Mar 18, 2006 #4 Heat range. Would you still use like RN9YC?
dustertogo Well-Known Member Joined Mar 7, 2006 Messages 880 Reaction score 209 Location Brandon, MS Mar 18, 2006 #5 If you've been running the N9Y it should work fine. Are you making any other changes to ignition or carburetion?
340Dart Obsessive Dart Disorder FABO Gold Member Joined Jan 8, 2005 Messages 778 Reaction score 233 Location Mount Morris, New York Mar 18, 2006 #6 No other changes except the heads. Thanks for the replies.
rumblefish360 I have escaped the EVIL Empire State! FABO Gold Member Joined Jun 21, 2005 Messages 49,798 Reaction score 23,731 Location Florida Mar 19, 2006 #7 Your answer is in the Edel. instruction sheet(s).
