Edelbrock SP2P-318 Intake. In good shape. Has a bolt stuck for the coil mount. I drilled it and tried to easy-out it but stripped my tool in the process. Can be tapped out easily. Rear 2 carb mounting holes are a little loose at the opening, but I was just going to use studs with blue locktite and it would be fine. Other than that it looks fine to me. I was going to use it on my Ramcharger, but I need an offset t-stat housing for the A/C compressor.
Asking $150.00 and I will pay the shipping to a U.S. postal address.
