crooked1/2dozen
Hey Y'all:
So I picked up an electronic slant6 ignition system out of an early '80s vintage D-100? pickup, plus, what I think is referred to as a squareback Chryco alternator with solid state regulator. I'm going to install these into my '64 Valiant. Some of the wiring upgrades to do one or the other appear to connect to each other. I know it's not good technique to do 2 upgrades at once, if you have trouble......it's harder to troubleshoot!
I think I'll do the alternator first, with some temporary wiring to the ballast resistor from the field coils, and make sure I'm charging, then once that is working OK, I'll do the ignition.
The ignition wiring to the ballast resistor on my "new" electronic harness are red and pink? not brown and blue as described in the Allpar conversion webpage, but I think I've figured out which is which.
I just have to get some new heavy gauge wire and a fusible link for the alternator, then.....let the fun begin.
I'll post later if all goes well...or otherwise.
Dan
Dan
