Electric Fuel Pump To Mechanical
srduster340
Decatur,Ga.
I'm planning to swap to a mechanical pump from a Mallory 140 electrical unit. I hear Carter makes a good pump. Engine is a 360/414 , Holley 800 DP, Eddy Air Gap, ported iron heads, .242/.250@ .050, .558/.573 lift solid cam, TTI headers, 2.5" exhaust, 833 four speed. This is a street car that may see the strip a few times. Suggestions will be appreciated.
I have the Carter 120gph one from Mancini. I have to use a regulator (I use the holley type) with it because the fuel pressure was a bit high. So far no issues whatsoever. I had the cheaper holley 75 gph or something like that and it was JUNK!!!
I run the Carter strip pump on two of my cars, no issues also using a Holley fuel pressure regulator
