Electric water pump and alternator
joes68340s
Rescue CA.
Anyone running an electric race type water pump with the stock type alternator and brackets. Are there pumps that this will work with. I know they take special backing plate some even a special timing chain cover.
I think you would be a lot happier building a custom low mount high amp alternator. Less prone to throwing belts, cleaner look, more amps to compensate for things like a water pump, fuel pump, nitrous, etc.
I run a moroso electric water pump with a stock style alternator using march pulleys and brackets with a surpantine belt,works great never had an issue
