Electrical Nightmares
Vetteman
New Member
New Jersey
My 69 dart i got 2 years ago have been a total electrical nightmare. The wiring harness was butcher. All the electrical was wack out. Electrical box on firewall was toasted. Rewired most of it. The problem now is that i swap over to an electronic ignition system.( 318cu.in) I wired everything up. I used a volt meter to check if theirs power in the system. Coil to ballast reistor, to electronic box all have power, but when i turn the key on to start the car everything goes dead. NO POWER. Key off power. Key on no power. Where is my wires cross? I got the diagram of how the setup goes and went over it ump teen times. Could my ignition switch went bad. The car will turn over if i use a screwdriver on the little relay box, but no power going to the coil. Theirs power going to and from the ballast resistor with key off. Nothing when key is in the on position.
