wanahemi
I got some unexpected gremlins that came with my recently purchased car. I bought a 68' 340 GTS Dart. (automatic) The engine has been converted to electronic ignition (4-pin module),Accel coil (stk. size one), stock electronic distributor, 2-pin resistor (changed) and mechanical fuel pump. The charging system is still the old electro-magnetic voltage regulator (changed). Edelbrock intake with a weird Edelbrock with Weber on the side carburetor. It has the electric choke hooked up with, I guess some sensor to raise the idle when the A/C is turned on.
The car runs fine for the first hour or so. After that, the idle starts to get bad, then sputter, sometimes backfire through the exhaust, then dies. Sometimes it will start right back up and does the same thing. Other times, it does not want to start up at all. Engine cranks, but no firing up. I thought it might be the module or bad ground on the module. But changing to a spare module and adding a groud wire did not change anything. Fuel pump maybe? The engine temp. is fine, never gets over 190. But this engine dying thing only happens when the engine has been running for awhile. Any ideas?
