Vetteman
New Member
While wiring up my coil i put the posi wire on the negative side and the negative on the posi. When i put power to it i heard a loud pop sound that sounded like it came from the coil. Did i fry the coil? Is the resister blown also. Just disconnect everything. Putting car together for the first time. Everything new. Electronic ignition in my 69 dart
