Electrician or someone that can
Cascade Regional Board
  1. Matts440
    Matts440 Well-Known Member
    2,573
    1406
    Apr 11, 2014
    Nampa, Idaho
    Local Time:
    10:21 PM
    Looking for someone who knows how to wire in 220v for my air compressor, to be honest never done it and nervous about wiring it myself.
  2. harrisonm
    harrisonm Well-Known Member
    3,182
    3284
    Jan 16, 2005
    Topeka, KS
    Local Time:
    4:21 AM
    I am TOTALLY not kidding when I say this. Either go to Lowes and buy a book or Google it. I googled it and I got hundreds of hits including videos. I wired a 240 volt sub panel in my garage and run my compressor, powder coating oven and garage heater from it. The heater and oven are operated from plug in receptacles that I wired from the sub panel. The compressor is hard wired and only has three wires going from the sub panel to the compressor (in a flexible plastic conduit, of course). I would not even ty to explain it to you when there are so many sources online with excellent pictures, wiring diagrams and videos available. Also, most 240 volt larger compressors are hard wired. No plug receptacle required. Also, if you do not feel comfortable, have it done. It will be money well spent.
    • Like Like x 3
    • Agree Agree x 2
    • Thanks! Thanks! x 1
    • Dave_J
      Dave_J Well-Known Member
      85
      97
      Nov 27, 2019
      Auburn, WA
      Local Time:
      8:21 PM
      I agree with Harrisonm on this. There are lots of information on the web. It is an easy job if you use the cautions and follow the electrical 'House Keeping' on running the wires. Only 1 hand in the electrical panel at a time, no exceptions. Hold both hands out to your sides and then think whats in the almost exact middle of your two hands. It goes Bump Bump.... Bump Bump
      1. You have to know the amp draw.
      2. You need to know the distance from the panel to the compressor.
      With these two items of information you can then pick the wire gauge to run.
      Now you also need a dedicated dual breaker of the correct amperage in the house/garage electrical panel.
      Most codes call for like a 12-2 gauge or 10-2. In this wire you will use the insulated White and Black to the two HOT lugs on that dual breaker. The bare copper goes to the ground buss bar.
      You are 8 hours away otherwise I'd ride over and hook you up for a beer and a good sandwich. ;)
    • jeff alder
      jeff alder slippery fish
      85
      86
      Nov 10, 2019
      crescent city illinois
      Local Time:
      10:21 PM
      look at max amperage on compressor name plate...buy a double pole breaker rated for that same amperage. look at the chart in "uglies" electrical reference (online) for maximum ampacities of conductors in free air. hook it up...piece of cake
      • Like Like x 1
      • Matts440
        2,573
        1406
        Apr 11, 2014
        Nampa, Idaho
        Local Time:
        10:21 PM
        Thanks for all the replys, I'll give it a go and get the right breaker, its not that high of a amp I think. Will look tonight
        • Like Like x 1
        • 89on35s
          89on35s Inferno Red Duster FABO Gold Member
          1,903
          2029
          May 11, 2006
          Martensville Sask. Can.
          Local Time:
          9:21 PM
          I am a Journeyman Electrian. If you can't find the answers you are looking for just message me and I can help you.
          Cley
          • Like Like x 4
          • Matts440
            2,573
            1406
            Apr 11, 2014
            Nampa, Idaho
            Local Time:
            10:21 PM
            Thanks everyone for all the help and advise, much appreciation
          • harrisonm
            3,182
            3284
            Jan 16, 2005
            Topeka, KS
            Local Time:
            4:21 AM
            Status?
          • Matts440
            2,573
            1406
            Apr 11, 2014
            Nampa, Idaho
            Local Time:
            10:21 PM
            Sorry forgot to update, got it all done and fires up nicely, so glad to have air back. Thanks again for everyone's help
            • Like Like x 2
