l...................., you must upgrade your voltage regulator and alternator. ..........................:
dont know if that is an electronic regulator or not, it is actualy a "constant output regulator,for drag racing only" http://www.summitracing.com/parts/DCC-3690732/Uh, no.......Look at the photo he posted. The "other" little box is an electronic regulator for the 69/ earlier alternator. Actually, if you ground one field terminal, you can use it on a 70/ later system as well.
The single field setup is like a on and off switch. Works great if you don't do a lot of idleing.
