Electronic ignition wiring
ike61
minnesota
Howdy. I volunteered to work on a friends 66 fury. The original wiring was all hacked to hell and I’m wiring in electronic ignition and electronic voltage regulator. One side of the ballast has a brown and blue wire. The other has a blue wire and a blue with a white tracer wire. What side do I tap into with the wire from the electronic Ecu? Thanks
Blue and blue white trace is the primary side of the ballast full 12v. This should power the box.
On the other side Brown is full 12v on start and the blue is coil feed. When in run the blue/ brown side is dropped through the ballast.
