Electronic Speedometer
BlindSquirrel
Wynnewood, PA
Hello, Guys and Gals,
I was just wondering if anyone is using an electronic (as compared to a mechanical speedometer, with a cable) speedometer. I am thinking of changing to an electronic speedometer, and am looking for some input.
Do you think that the VSS from my junkyard bound '95 Plymouth Voyager would work with an electronic speedo, or do I need to purchase a sending unit from the speedo manufacturer? Also, in my research I saw some electronic sending units that had stated 3500 RPM Max. Seems kind of low for Max RPM's.
Thanks for any information you can provide.
BlindSquirrel
I've got an electronic Autometer speedo and sending unit. There are no limits on RPM that I'm aware of and I think it would be a lot easier to use their sender than trying to adapt an OEM unit.
