There are actually only two that need to be connected. You can then use the original coil + wire to feed the 'small red' on the MSD The second "half" of the resistor fed back to the module, so it is not used
Easy way to identify--put meter on coil+, and turn key to "run." Leave the two on one end of the resistor which are jumpered together alone. Pull one of the other two. If the meter drops that is the one you want to jumper to the ones on the other end of the resistor.
Follow MSD destructions closely and NOTE Do NOT connect ANY other wiring to the coil with an MSD. Not the original radio cap, and not your tach. ONLY the two wires from the MSD should be connected to coil
