EMERGENCY BRAKE STRUT LEVER
DavidLee
Torrance, CA
Can I use the same one from my 10" small bolt pattern on the large bolt pattern setup?
Yes you can, info and pictures are here
E-Brake help please
You can't use the brake struts from a 10" BBP brake set up on a 10" SBP brake set up, but you can use the 10" SBP struts on a 10" BBP set up.
