rod7515
Working on my 66 Dart. I've added frame rail connectors and will be running a 3" exhaust system. I had to cut the original cable mounts off and was hoping to see what modifications others may have done so that you still have use of your e-brake. Also any pics of where you may have run your steel brake lines back through at. Hoping to start on this part of my build this week.
Thanks Rod
Thanks Rod
