Engine bay mods done and in epoxy primer.
So the "green pearl clear"......is that like a modern version of the transparent colors we used to shoot to get candy effects?
yes it will be a tri-coat job. Base will be solid color. If you add pearl to base it will tint it and pearl effect will be lost. Mix pearl into clear and top coat the base. Then final clear. It should give a deep look to it.
Here is quarter install. This was an AMD skin and it fit very well. Body guy was impressed.
Been following this on another site. Great work. Jealous of your skills brother.
Sorry for your bad luck. As others have said, you have some very impressive skills. I hope your knuckles heal so you can continue to rebuild your vision.
