Engine Compartment wiring??
dart4forte
Mesa, AZ
I started laying out my new engine harness. It's been awhile. Can someone send me some pics of their engine bay and how their harness lays out?
Are you guys using stickers for the pie tin? My pie tin doesn't join together.
Not to hijack the thread, I was interested in seeing how the forward harness lays on the inner fender. I have race headers that will prevent me from running any wires down the inner fender unless they are run out to the actual fender edge.
The wiring stays inside the engine compartment. There are some stamped recesses that it kind of runs along There are plastic clips that hold it in place. From what I have seen from the earlier post. Starter relay torwards the passenger side of the bulkhead. Voltage regulator to the drivers side of the bulkhead. and horn relay on the other side of that. Very close to the inner fender on the fire wall.
Hey caveman: what are you using for a windshield washer bag?
Ford ?Mustang/? bag off ebay.
one side is black with white printing.
I wiped it down with Paint thinner waited a day, and painted it Krylon Semi-flat black. 8)
I can't run mine down the recess due to the headers. My only question is where the wiring splits off at the fender plug.
it goes between the radiator and the radiator support and drops down thru the hole in top of fender aprons to feed the headlights,and the turnsignal wiring comes up thru the same hole and attaches then you put in the round body plug that has a split in it and a hole for the wiring
You wouldn't have a pic?
