Yep, and aren't there things inside the torque converter that rattle around just a bit when the transmission isn't hooked to it? Taco about out-of-balance and shaking around.I wouldn't do it... Flex plate can flex, oil may go everywhere causing it to be of balance... Stick a transmission behind it - just make sure it's in nuetral and you run a hose or steel line between the two cooler fittings.
Yes, that is what worries me most that the TC will start to flex and come off from the crank.I wouldn't do it... Flex plate can flex, oil may go everywhere causing it to be of balance... Stick a transmission behind it - just make sure it's in nuetral and you run a hose or steel line between the two cooler fittings.
I'd be using a fly wheel.
The "flex" plate does just that, remember.
How about the starter, figure where you're gonna bolt that up to?
I'm wondering, if you leave the transmission off with the torque converter installed, how do you plan to start the engine? With a pull rope? A speed wrench? Are you just going to jerk on the ring gear with gloved hands? Maybe push start it sideways? I know, 1" drive impact wrench on the damper bolt!
FWIW, I built my engine test stand to be used with a flywheel and a manual trans bell housing. No trans hooked up.
I wouldn't do that to ya. I read your response. I don't want you to feel ignored so's I gave you a 'like', okay? I just though I could be funnier, or was it show less mercy? You did good MOPAROFFICIAL, you did good.Is there an echo or what.
Pretty soon we'll all have each other on ignore.
Thanks, exactly what I was thinking.
I have my reciprocating assembly balanced with it on there.
I figured it was for a simple break in / try out run for oil leak inspection.
