MOPARJ
What can I upgrade now?
While driving home yesterday evening in my Dart, I encountered some issues. I exited the freeway and noticed the exhaust had more of a pop to it as I was decelerating. When I came to a stop at the light, the idle was lower and the motor was not running smoothly. It did not have just one cylinder down, it sounded like all where firing weakly. When I put the car into neutral and rev the motor easily, it sounded really weak, like it was running out of fuel, not sputtering though. After a about 1000 rpm, the motor sounded like it abrubtly began running a little stronger, but even while holding the rpms at 1,500, the revs where still vaining up and down, plus there is some popping from the exhaust. I had a spare ECU, so I swapped it, to no help. I limped the car home. When at home, I noticed that everytime I shut the car off and restarted it, it would run fine, until I revved the motor to around 2,000 rpm or so and held it for a second. As soon as I let off the gas, the motor began running like crap again. Its hard to describe what it sounds like, but I know its not just one cylinder. It sounds like a 4 cylinder until you bring the revs up, then it sounds like the cylinders come back on line somewhat. It will continue running like this until you shut the car off, then it will be fine when restarting until the revs are brought up again. I repeated this process ten times with the same result.
At first, judging by hoe the engine was running and sounded, I thought it may be fuel related, but once I did the shut down and restart process, I kinda moved away from that. It seems like something electrical that resets itself or frees up when shut down, but craps out again after holding at a certain rpm after restart. I checked the vaccuum advance by plugging it and going through the running process, to no avail.
I am beginning to lean towards something in the distributor, but the only thing I can think of is the magnetic pickup, but usually when it goes, it just goes. Could be the coil, but seems like weird circumstances for it to fail.
If there is one thing that I would rule out, I would say mechanical failure within the engine, as something like that would be more constant IMHO.
Help me out if you can with opinions.
