[SOLD] Engine mount bracket, 318 mid 80s D250 4x4 pickup truck
physixx
Edison, NJ
I have for sale an engine mount bracket that came from the driver side of a 318 mid 80s D250 4x4 pickup truck. This bracket will fit many year trucks, both 2x4 and 4x4 along with the other models. It’s been cleaned and painted and the attaching nuts and bolts are included, also cleaned and painted. I would like to get $20 for everything plus the shipping.
Ken
Edison, NJ
Is this the one that can be used as a "conversion mount" to install a 360 into a /6 K frame?
This mount is the OEM driver side mount from my friend's 318 truck. The separation of the ears on the block is wider on the 318 so won't fit unless you add some washers or spacer to make up the difference in the separation to fit the 360.
