Engine positioning measurements for 69 A body?
Machined
Active Member
With a 383 what are the measurements in between frame rails and up from the k member to the center of crank? Thanks
From the center of the crank to the top of the K frame should be 5 1/4". The engine sites towards the passenger side by 2 1/2 ", Measure from the crank bolt to each frame rail.
