Engine tilter/leveler options
Shop, Garage and Tools
  1. sabre67
    sabre67 FABO Gold Member FABO Gold Member
    691
    159
    Jan 9, 2015
    British Columbia,Canada
    Local Time:
    2:13 AM
    Hi all I'm looking to buy a engine tilter/leveler attachment for my engine hoist. On Ebay they range from $52.00 to $179.00 Any suggestions would be appreciated or what your using would help. And what is the combined weight of a fully dressed 383 and 727 trans? thanks in advance of your opinions :thankyou:
  2. pishta
    pishta I know I'm right....
    17,253
    6872
    Oct 13, 2004
    Tustin, CA
    Local Time:
    2:13 AM
    The load lever I got (cheap US tool) had chains that were quite long and made getting the motor up and "over the hump" (radiator support or fender) impossible so I had to lower it and get another bite on it at an extended boom length, just an FYI as it does add to the overall chain length. The handle to turn the leveler was too small and it was near impossible to turn it when the motor was slung. Lather up that worm drive with grease.
    • Like Like x 1
    • ValiantOne
      ValiantOne Well-Known Member
      1,089
      214
      Mar 20, 2008
      Communist Maryland
      Local Time:
      5:13 AM
      I bought the one from summit racing. Had to shorten the chain on my hoist and choke up on the leveler chains too. Also the crank for the worm drive was useless and i had to fab one out of large dia rod. As mentioned grease that sucker up.
    • Mopar Sam
      Mopar Sam Well Fed Member
      995
      1349
      Jul 18, 2008
      Indiana
      Local Time:
      5:13 AM
      I got rid of the crank handle and welded a nut on mine, so I could use my 1/2 inch impact on it. It works much faster that way.
      • Like Like x 1
      • halifaxhops
        halifaxhops It's going to get stupid around here! FABO Gold Member
        59,151
        27435
        Jan 20, 2014
        CENTRURAL, PA
        Local Time:
        5:13 AM
        I have a cheap HF one it works ok but the handle is a pain might do the nut on it like stated above.
      • RogerRamRod
        RogerRamRod The Older I Get, The Faster I Was
        918
        518
        Jul 5, 2011
        Chesapeake VA
        Local Time:
        4:13 AM
        I don't think I would want to be swinging the weight of an engine and trans, and changing the CG with an adjuster that high in the air, over the front of the car (and me). I'd save the money and install them each on their own. Now, with a gantry crane and a chain hoist....
      • halifaxhops
        59,151
        27435
        Jan 20, 2014
        CENTRURAL, PA
        Local Time:
        5:13 AM
        Any one use a engine plate? I just don't trust them lifting a engine on a aluminum manifold.
      • MOPARMITCH
        MOPARMITCH Mekong Gold Member FABO Gold Member
        20,729
        11387
        May 15, 2013
        Maryland
        Local Time:
        5:13 AM
        Used em many times on alum intake. Just gotta be sure to have the correct thread bolts , and snugged down good.
