69GT Well-Known Member Joined Nov 18, 2009 Messages 1,454 Reaction score 262 Location Metro Detroit Mar 3, 2024 #1 On a 69 Dart, where does the engine to firewall ground wire attach? Big block if it matters. I was thinking from the rear of the block on the passenger side to one of the heater blower motor nuts.
Murray FABO Gold Member FABO Gold Member Joined Apr 19, 2010 Messages 3,959 Reaction score 3,233 Location San Jose, California Mar 3, 2024 #2 Right rear intake bolt to firewall hole just for the ground wire, just to the left of heater motor bolts.
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 15,827 Reaction score 13,169 Location Northern Colorado Mar 3, 2024 #3 2x heat only firewall 1x AC firewall AC FIREWALL Red is the block ground Yellow is the fan motor ground Last edited: Mar 3, 2024
