I am looking for an engine to transmission bracket like the one in this picture. It bolts just below the starter on driver side of the engine.
It must come from a car that had a manual transmission. Manual trans only had the little tab for the clutch fork spring and the one from an auto will be clocked slightly different ( I tried one from an auto already)
this is for a 1972 car so I am not sure if early As had the same part but I am sure 68-76 should work.
