bremereric
What is this used for?
Looks like the tool for removing pins from a flywheel or engine block.
x2pilot bushing tool?
Dowel pin remover. Screw on the correct end for the dowel pin you need to remove. Place it over the dowen pin. Pound the collar over the end and then pound the handle once in the other direction and out comes the dowel pin. :cheers:Looks like the tool for removing pins from a flywheel or engine block.
Nah it works like a charm and it's not mine. I borrowed it from my machine shop I use. Years of use is what you see.It is a poorly maintained striking tool. Go clean up all of that damage before someone gets hurt.
B.
