Engine up grade!!!!!!!!!
64fish
Member
I am rehabbing a 64 Barracuda and am installing a 1988 318cid. Can anyone tell me if they know anyone that makes a motor mount for this application? This would be a great help. Thanks
I would think that motor mounts from a 273 from a 64-66 A body would work? I'm sure, correct me anyone if i'm wrong, that the 273 and 318 share the same mount/oil pan in these cars, and to put a 340 or 360 in you would have to get different ones.
no, 340 mmounts are different on the left side only. The spacing is different on the mounting tabs on the block, and also there is a different bracket for 340's between an A body and n E body.
