I think that is likely targeted to industrial use. A low pressure gun my not spray it.
Does the label state it could be applied with a brush straight from the can ?
We used a product something like that in the textile mill where steam caused rust.
you need to read what the can of filler says. Most will say it can be used over primers. Some will say bare metal.
what brands are available to you ?
ok thanx.will chek thatDN or DP ? DP is the epoxy. DP is pretty good. The number at the end is just the color so any DP series primer will work.
