WacDad Miller
Member
Anybody that are using the Magnum EQ heads, what valve covers are you using. I have a set of M/T covers for an LA, the bolt pattern will work. However, the sealing surface on the EQ heads are so thick, the valve covers wont clear the edges. Any ideas? I could mill the covers, but, rather not do that.
