[SOLD] Erson Small Block 1.6 Ratio Roller Rockers - New
Rocket
CT
I have a new Erson billet aluminum roller rocker kit in 1.6 ratio for small block engines using LA style heads. Kit includes the rockers, spacers and shafts. Part number is E918572. These have been stored since they were originally purchased and in perfect shape.
These rocker arms utilize a shaft that is smaller in diameter but greater wall thickness than a stock shaft to allow more meat on the rocker arm for strength. The shafts come with sleeves that slide over the shaft to create a standard diameter area where the shaft sits on the pedestal and hold down. The assembly is easily disassembled by removing a clip on either end. The shafts are also equipped with threaded plugs on the end to allow for easy cleaning and inspection of the shaft versus the stock type press in plugs.
Description from the Erson catalogue is as follows
BILLET-ALUMINUM ROCKER ARMS
This high-quality, billet rocker arm is machined from 7075-T6 aluminum. The tip itself is made from bearing quality steel. The unique profile of this new rocker decreases deflection without increasing weight. Wider needle roller-bearings deliver better load distribution from high-pressure springs.
CHRYSLER BILLET-ROLLER ROCKER ARMS
These are “true” roller-rockers, with needle bearings at the pivot point to minimize the galling and breakage that can occur when using rockers with no bearings. A roller at the valve-tip reduces side load on the valve-stem. Bodies are machined from heat-treated 7000 series extruded aluminum (instead of the lower cost 2000 or 6000 series) for ultra-high strength. Unique truss-shape deflects less than any other aluminum rocker. Higher-than-stock ratios deliver higher valve-lift and greater effective duration. Wall thickness of the rocker-shafts is greater-than-stock to reduce flexing when using stiff springs. All shafts are heat-treated and centerless ground to ensure straightness.
This is a strong, high quality kit that was made here in America. Parts will be delivered in their original packaging.
Price is $640 including shipping in the lower 48 states. I can ship internationally for the additional shipping cost. PM me with questions.
Do you know if they require cup style pushrods or if they work with the standard LA stle ball-ball type pushrods?
Thx
They come equipped with adjusters for the ball and cup style pushrods. There are aftermarket adjusters available if you prefer to use ball and ball style pushrods.
I need something for ball-ball pushrods as i've got my pushrods already.
If you are interested in the rockers I will substitute the adjusters with a new set of adjusters that accept ball end pushrods. See photos. PM me if interested.
Thank you
Let me check some numbers this week for my valvetrain to make sure the 1.6 ratio works and my valves won't be kissing the pistons and I'll get back to you. Interested in those adjusters indeed :)
I've checked my numbers and 1.6 ratio will be too agressive, that's taking too close to piston-valve contact :(
Good luck with the sale.
