Lookin for insight on espo springs before I order some. Deciding tween stock +1” or stock +2”. Thanks for any help. Replacing old stock rear springs on a 67 barracuda
Don’t look like they settled too much. They don’t ride rough? I’ve a 67 notchThanks, It’s settled a little, that was several years ago. This was last summer
The after is stock or +2 ?Before and After Shots of a '65... +2" Will put you Way up there!
a +1" would probably look more normal?
Do you have pictures of your set up ?Here is the key factor to me. All the Espo Springs that I have installed in 4 Darts are high when they first go in and understandably settle down in the first couple years (depending on how much you drive it and how much of a load you put in it). I find that +2 is where I want it to be after all is settled out. The same thing happened to all these cars with the stock springs and then they were too low and too squishy.
Remember to get the 340 style 6 leaf springs...
So -2 or stock would put the lip of the body on top of the lip of the rim ?
I assume how the car sits? The springs in the purple car are 6 months old, The ones in the white car with black scoops are 10 to 15 years old and the ones in the white car with black roof are 15 years old. The first two are installed with the MP 3/4 inch relocation kit.Do you have pictures of your set up ?
