estimate hp please
dart6
New Zealand
Just trying to get an idea where we might be at.
I have a 71 360 30 thou over with very low milage, wiend stealth dp manifold, j heads with 2.02 valves, cr9.5, cam lift @50 in464= ex 436, dur @50 on the cam card says in 212.6, ex 225.2
carb would be a holley 650 vac maybe 750 vac. Any guesses to possible hp, tq
Also I have have a second cam as well which is .470 lift in & ex@50 dur @50 232
all cam lifts are with 1.5 rocker ratio
Appreciate any comments
Is this a fun car or a driver? I like your 2nd cam choice better if it's a fun car.
I'd guess high 2's to 300hp with your initial thought's. How it performs will depend on your gearing & converter, if it's a auto trans?
id run the bigger can and about a 2500- 2800 stall and you will love it and a great driver:D
