Excellent video
On Steve’s YouTube channel go to his playlists and look at Steve tech. There is a plug read video that is the best one on the Internet.
Different plugs from different engines same tuner. Notice the mixture shows up on the porcelain as well. They are all pump fuel.
This ones a DOOZY!
This is what Greg wrote about this particular plug and the reason for why its tanned all the way down to the eventual boundary layer:
BP 98 fuel.. (That's a premium pump fuel)
Now car has no pinging ...
Clean all the way to the bottom.. that means that as the afr gets closer to the head it’s still well mixed... as you get closer to the boundary layer near the chamber wall it gets colder usually and that changes the burn and the gas type that gets produced from the burn at that point .. you can see this on plugs..
This ones a DOOZY!
I meant you need to EXPLAIN what you are seeing in the pictures and what that means. Not everyone knows exactly what they are looking at.
Thats why I said to make your points a bit more clear.
People say that pump gas doesn't color plugs, Greg doesn't have a problem getting it coloured all the way down to the boundary layer.
