ERACER
I have a 318 in my '74 Dart that was freshened in spring '07 with new bearings, rings, cam and lifters, valve springs, and so on. I only ran the car a couple of times that year and not at all last year, so it might have about 100 miles on it. Early last week, I got it running again and noticed that every time I hit the throttle, the balancer and pulley move forward about 1/16". At first I thought the balancer bolt had loosened, but after checking it, the balancer is fully seated and the bolt is fully tourqued. With the engine off, I was able to get a pry bar between the balancer and timing cover and sure enough, I can pull the balancer forward exactly 1/16". I did look from underneath and the flexplate comes forward with it, so I know the whole crank is moving (which is a positive), but according to my incredibly sharp math skills, I have about .055 too much end play. What happens to an engine with too much slop and is this repairable with a wider thrust bearing?
