Once welded up there is no going back. Locking it open ( and keeping it lubed) if you change your mind you canCut it out, weld up the holes and never look back
Disable. You don't need the extra heat at the carb.Quick question.. Using stock 340 manifolds, keep, remove, disable damper?? Stock rebuild 20 over nothing fancy, restoring a nice driver 71 demon for my daughter. Thanks
Electric choke is ONE way to go, but not the only way. He's restoring/stock rebuild; nothing wrong with that.electric choke is the way to go!
