exhaust manifolds e body /a body
jonesboys
waynesboro
need info on e body hp manifolds will they work in an a body dart 1973 manifolds if it matters ?
The exhaust manifolds from E body to A body are different. Won't fit the A bodies.
E Body exhaust manifolds:
A Body exhaust manifolds:
340 HP ^^^
Those are 1970 E body manifolds which are the same as 1970 A body. 71-4 E/B body are different. For 73 the pass side is the same for A/B/E. Drivers A is different then B/E.
So to answer the OP's question is yes for the pass side and no for the driver's side for 71-4 manifolds. 1970 E, yes on both sides.
The a body manifolds were used on the AAR and T/A's . All other models used the same mainfolds 70 - 74
you can find these on some E/B bodies. I've used them on A-bodies
Sorry I have to disagree. We had three 1970 340-4bbl E bodies and they had the A manifolds.
Casting numbers.
2863549 2863553 1970 A/E
3418621 1971-73 B/E/C, 3418623 1971-73 A/B/E/C
According to GG white books
Parts numbers
1970 A/E 2863545 2863552
1971 A/B/E Rt 3418624. B/E Lt. 3418620. A Lt.2863552
According to the FPM.
I think the 2 of you are saying the same thing, just a different way. Steve meant the 68-70 340 HP manifolds were used on AAR's and T/A's, which would have been the exact same manifolds as A66 340 cars. B, C and E bodies used different drivers sides from 71 up.
