exhaust manifolds for 67 barracuda with 383
msj1959
New Member
Socal
Any suggestions for exhaust manifolds for my 67 with 383? The freeze plugs are done and I'm planning on pulling the engine for a rebuild and want to upgrade the exhaust manifolds. I will probably replace the intake manifold and the carb as well. I would appreciate any comments or suggestions.
Mike
my passenger side is # 2899876, which is a 70-73 big block manifold....and i'd imagine the driver's side is the same, but different number for driver's side....i don't see a number on it anywhere....but they fit really well.....i'm going to get headers, so if you need manifolds, i may be a good source.....
HI this is kevin from farmington michigan.I would like to no if theses exhaust manfolds are still around .You said you were going to a set of headers?I am working on a project mopar 440 in a duster and have got the engine now in the car .Let me no on the cost you will sell these would like to purchase for my car thanks Kevin .248-476-7008 [email protected] MOPARS RULE! This is the ad i read on a body only My passenger side is # 2899876, which is a 70-73 big block manifold....and i'd imagine the driver's side is the same, but different number for driver's side....i don't see a number on it anywhere....but they fit really well.....i'm going to get headers, so if you need manifolds, i may be a good source.....
You can run b-body HP manifolds. There may be a need to shorten the outer sleeve on the steering column up to the firewall. That need is there if you run the 67 driver side manifold on a 383 (won't fit with a 440) or with the 68-73 manifolds on an RB. I have a 383 with some 73 manifolds in my 67 Barracuda, but I have yet to install the steering column.
If your '67 Formula 'S' has the original manifolds, I suggest that you keep them if you do go with other manifolds.
If not, they are still @ a $600 pair of manifolds on the market, maybe more.
Mark.
I`ve heard that Layson`s sells a LH manifold that will outflow the factory unit but I have no personal experience with it. For the right side you can use the HP B-body unit as Jim said. You might take a look at Bigblockdart.com ,I`ve seen articles on there in regards to this same question.
There's really no flow difference between the a-body and b-body right side manifold, just a slight difference in the downpipe portion.
