exhaust riser leak
Slant Six Bumblebee
vancouver wa
There is a exhaust leak on the heat riser. I replaced the gasket but that did not work. I think it did not work because the stud on the exhaust manifold side had snapped. So i drilled it out and taped it but when i reassembled it the threads broke so i could not get enough tension on the gasket hence the leak. Any suggestions? (my thought it to drill the hole over and retap it then use some permatex high temp gasket maker.)
Hello Slant Six Bumblebee,
Possible to use a Heli-coil on it ?
https://www.grainger.com/product/HE...50,+0.375,+0.500+in++Length&suggestConfigId=8
Note: link is for 1/4 20... You would need the kit for your bolt size.
Hope this may help.
Stay Safe....
Happy Mopar :)
Arron.
https://www.grainger.com/product/HELI-COIL-304-Stainless-Steel-Thread-4DCD7?internalSearchTerm=304+Stainless+Steel+Thread+Repair+Kit,+1/4"-28+Size,+12+Ea.+0.250,+0.375,+0.500+in++Length&suggestConfigId=8
Hope this may help.
Stay Safe....
Happy Mopar :)
Arron.
a heli coil would be possible what would you recommend for a gasket. I was thinking either using coper permatex make a gasket or i could get the graphite gasket but would rather not spend the money or wait the shipping time.
When I got my 85 pickup the manifolds were off the truck, and the firewall was coal-black. That gasket had blown out on it, and the POs son had pulled it apart to fix. It had sat apart for a couple of years like that. The old buzzard had said that he thought he had scrapped the manifolds, his son was there when I loaded it on the trailer and dug out a set of manifolds that the old man either forgot about or didn't know was there in the first place.
Some idiot had poked a 1" hole in the wall of the exhaust manifold where the inner bolt closer to the head is, and ruined it. I found one in a local junkyard and had to take it to a friend of my son's, who has a machine shop to drill out and retap the 2 outer holes for me, and then when I got it on the truck, it would barely run for many reasons/ the worst of which was that the front cat had disintegrated, and it's guts had clogged the rear cat. This was what blew out that shim steel gasket originally in the first place. I went dumpster diving at a muffler shop and got some nice clean stainless steel bends off of some sort of newer vehicle, and cut the original front cat off, used that flange and pipe stub, welded up myself a new exhaust from the manifold to the existing muffler. Only after doing that, and straightening out the old buzzards wiring hacks I finally got it to run.
You might check for some sort of exhaust restriction retaining heat, as to why yours blew out.
A funny continuation to the story of my truck, I was getting gas in my daily driver Dakota one day after work and a 91-2-3 D150 pulled up on the other side of the pumps from me.(unsure of exact year, it had the ugly grille was all I knew)
I said something to him about wishing I could find a decent older truck like that and somewhere in the conversation the town 2 towns over from where we were at came up, he said he knew of a couple of them over there.
I told him I bought a maroon and white one over there, a while back. he asked if that was the one with the slant 6 in it, I said "yeah".
His reply was that "oh I know that one, it has no compression" I laughed and told him what was really wrong with it, I haven't measured it's compression yet, but once I got it uncorked, it runs fine. I didn't have to do anything to it that has anything to do with compression issues, I have not yet had the valve cover off of it. The stare that he gave me was one of those "if looks could kill" moments.
Oh and 1 more thing,
I bolted the manifolds together using stainless steel grade #316 bolts to assemble the manifolds to each other and plenty of anti seize
I said something to him about wishing I could find a decent older truck like that and somewhere in the conversation the town 2 over from where we were came up, he said he knew of a couple of them over there.
I told him I bought a maroon and white one over there, he asked if that was the one with the slant 6 in it, I said "yeah".
His reply was that "oh I know that one, it has no compression" I laughed and told him what was really wrong with it, I haven't measured it, but once I got it uncorked it runs fine. I didn't have to do anything to it that has anything to do with compression issues, I have not yet had the valve cover off of it. The stare that he gave me was one of those "if looks could kill" moments.
My dart is from 72 and does not have a cat. I am planing to replace the exhaust pipe soon. I think it was leaking because the bolts were really loose when i first pulled it. How big can i drill that rear stud out before i have problems. Right now i have 7/16th threads that are broken off so i am thinking i will have to drill it out to 7/16th and either use a heli coil or tap it with 1/2in threads.
I have all grade 8 bolts
That's fine for now but those are regular steel. Not stainless. I hope you at least anti seized the threads where they thread into the exhaust manifold. Otherwise give them a couple of years and if you have to dismantle them from then on expect to be back at square one fighting them to get them apart again without breakage
