Just noticed light exhaust ..smoke comming off the left bank(left exhaust pipe)It is in a 72 dart,318,4bbl ,headers. Engine was rebuilt about 4 years ago. The right side has no sign of smoke. Ideas???
A lot of people mistake oil smoke (light blue) for white. Tell me this.....does the smoke dissipate almost instantly or does is hang out for a little bit?
- I would say light/white.
Then that's oil and it's very likely light blue. Steam from burned coolant will dissipate almost immediately.The smoke stays for a bit(10/15 seconds). I did not smell anything when i put it in the shop(walking into the smoke).
I'm unsure I would. Does the smoke clear up once it runs? Also does it smoke every single time or does it only do it on initial startup after sitting for a bit?Thanks for the help. Have the winter season to dig into it.
Save us some.Going to eat dinner ,will be back in about an hour.
i noticed it when i was opening the door to my shop. Was returning from a car show that was about 15 miles away(so car was warmed up, running normal temp.)I put it in the shop to check trans. fluid(it is a 904). The smoke did not run me out. This is the first time i saw the smoke. When i started it this morning it seemed fine(no smoke) I am used to start up smoke that disipates almost immediatly.
I've never had a poop sammich. I've always said my wife, Kitty is such a good cook that if someone could make poop taste good, it'd be here, but I've never taken the plunge. What all do you eat on a poop sammich? Inquirin minds and all that.Does the smoke get worse at idle and high vacuum? If so that’s usually valve seals/guides. If it does it under load, that’s usually rings. If it does it all the time…that’s a bit of a poop sandwhich.
First things first, fix the coolant leak and report back.It does have coolant. It has an intake manifold leak i plan to fix soon,but it has coolant to the radiator top.
